1,200 millimeters: More clearance than ever before!
We have found that having clearance is a good thing and the more, the better. This is also true for high-productive complete machining of large volume, demanding structural components in the automotive industry. Last year, the CHIRON 25 Series set a new standard in this area with a spindle clearance of 800 mm. This standard has now been extended to a larger size: With the new DZ 28 and its spindle clearance of 1,200 mm.
read time: 13 min Artikeldatum: read this article on one page
The shift in manufacturing processes is placing higher demands on production technology, for example with complex hybrid drives, lightweight construction of vehicular and structural components, battery trays and more efficient combustion engines.
Machining processes must be as dynamic as they are precise and it must be possible to configure the machining centers flexibly in line with specifications. All the better if the entire process is easily accessible and easy to see. Or you could simply opt for the DZ 28.
The right model for every application
The new series is available in two machine variants, the DZ 28 P five axis – P for pallet changer – for high quantities and short cycle times, or the DZ 28 S five axis – for direct loading. The new series will be available to order from 2021.
»With the 28 Series, we are addressing new customers and workpieces. Whereas previously, components of this size could only be used for single-spindle manufacturing, the new DZ 28 twin-spindle machines have considerably shorter cycle times – while also producing the best part quality.«
Kristoffer Siegmann
Head of Global Account Management Automotive at CHIRON Group
Grand in all respects, except for its launch.
Kristoffer Siegmann is satisfied with initial feedback from the market. »We got a very encouraging response from our customers. Completing our range is exactly the right way for us to go. The market wants to see machines which effortlessly manage extremely high quality requirements – like thin-walled components as well as high form and positional tolerances.«
Facts and figures
X-Y-Z travel distances Max. 1,200–1,100–800 mm
X-Y-Z rapid traverse speeds Max. 120–75–75 m/min
Spindle clearance 1,200 mm
Tool holder HSK-A63
Workpiece diameter 1,200 mm
Workpiece height Up to 750 mm
Palette size (for P variant) 800 x 800 mm
With a spindle clearance of 1,200 mm, the new DZ 28 is predestined for five-axis machining, for example for integral supports, longitudinal supports, large suspension holders, battery cases for hybrid vehicles and housings for power electronics.
The operating and loading sides are separated. The working area is always easily accessible and the process easy to see.
 Loading and unloading side of the DZ 28 S five-axis
 Operating side of the DZ 28 S five-axis
Other major advantages include the flexible machine layout with a small footprint, high dynamics, spindles which can be moved fully independently on the Z and X axes and its automation via robots or gantry. The machining center is operated using TouchLine, the established operating system from the SmartLine range. The machine condition can be monitored at all times on the large panel.
A tried-and-tested machine concept in a new size
A platform in a portal design forms the basis of the machine concept with a small footprint from 30 m2. The rigid machine bed and active component cooling enable the required degree of precision on the workpiece. High axis acceleration and fast rapid traverses ensure dynamic machining as never before seen with workpiece dimensions of this size. The machine concept is also very flexible. Whether machining complex workpieces with many tools or workpiece families – the two magazines offer space for up to 60 tools and therefore mean minimum set-up for manufacturing. Workpieces are loaded and unloaded during machine operation.
Unlock the full potential: With SmartLine
As with all of the CHIRON Group's new series, the 28 Series is prepared for integration of all SmartLine modules. For example, this includes ProtectLinefor preventive protection against machine crashes and ConditionLine for automatic condition monitoring of relevant machine components.
Want to find out more the new size for precise and dynamic machining? Kristoffer Siegmann, Head of Global Account Management Automotive, would be happy to answer any calls or e-mails.
Kristoffer Siegmann
Phone: +49 (0) 7461 940 3074
E-mobility: Technology with a history?
It is not just in recent times that the e-mobility sector has been booming. Around 1900, there were 34,000 electrically powered vehicles on the roads of the USA. Read on to find out more about how this sector has since developed in a brief history of e-mobility.
Brief history of e-mobility
You would do well to remember Michael Faraday when you are driving your car through a storm – his electric cage means that you are protected against any lightning strikes. Faraday was a natural scientist and in 1821 he proved how electromagnetism could be used to generate continuous rotation, the starting point of e-mobility.
Scottish inventor Robert Anderson created a form of electrical carts, which was followed by his invention of an electric vehicle in 1839. Robert Davis, another Scotsman, was the first to invent an electrically powered vehicle for rail tracks.
American Charles Grafton Page came up with the idea of creating an electrically powered locomotive. This vehicle reached speeds of 31 kilometers per hour on a test run.
The invention of a chargeable lead-acid battery marked an important step in e-mobility, and it would go into production the very next year.
Camille Faure improved the lead-acid battery, coating the lead plates with a mixture of lead sulphates. This greatly increased the battery's capacity. Faure's battery is the reason why Paris is known as the »City of Light«, as it had the first street to be lit by electric lighting.
The Ayrton and Perry electric tricycle caused a great stir on London's Victoria Street. The joint invention by William Edward Ayrton and John Perry had a fully electric drive and could travel up to 40 kilometers at up to 14 km/h on a single battery charge.
The first electric car, the Flocken Elektrowagen, was manufactured in Germany. Visually, the model with its cabin looks more like a carriage.
At the world exhibition in Paris, Ferdinand Porsche entered the public spotlight with an electric car he had designed while under the employment of Jacob Lohner at the Lohner-Werke firm. The "Lohner-Porsche" had front-wheel hub-mounted motors. He also gave a lot of thought to what would potentially be the car's small range. This is why he included a mixed-use electric and combustion engine.
Approximately 34,000 electrically powered cars were on American roads, some of which had impressive ranges of 100 kilometers or more.
Between 1896 and 1939, there were 565 manufacturers of electric vehicles around the world. In Germany, this included brands such as Siemens, Hercules, Kühlstein and the Fahrzeugfabrik Eisenach.
»Within a year, I hope, we shall begin the manufacture of an electric automobile,« said Henry Ford in an interview with the New York Times in January 1914.
Following a long break, Ford showcased a pure all-electric prototype in the form of the »Ford Comuta« microcar. The model had 12 V batteries, a range of approximately 60 km and a top speed of 55 km/h.
In the United States and, particularly the United Kingdom, milk bottles were delivered to customers' front doors each day by electrically powered milk floats.
The oil crisis brought about a real change in thinking. There was an increasing awareness of environmental issues and alternative drives came back to the fore. In addition, the Californian government passed an act to encourage the automotive industry to innovate and to switch its car production to emission-free vehicles.
The Horlacher Sport I concept vehicle traveled a record distance of 547 kilometers on a single battery charge.
VW constructed the Citystromer, a variant of the VW Golf II and III converted into an electric vehicle.
An example of particularly innovative work is the Hotzenblitz model, manufactured between 1993 and 1996 in the city of Suhl in the central German state of Thuringia. The two-person vehicle was developed in the south-western German region of Hotzenwald and, at the time, was the most consistent electric car in Germany.
Tesla showcased its Roadster at the Santa Monica Airport in California. Small series production would begin in March 2008. By 2012, approximately 2450 models of the two-seater sports car had been manufactured and sold all around the world.
Nissan released the »Leaf«, the first large series electric car designed exclusively for this type of drive. With its various models and cumulative sales of 450,000 units (as of January 2020), the Nissan Leaf is the world's bestselling electric vehicle.
Germany celebrated 125 years of e-mobility production and BMW presented the BMW i3, a plug-in hybrid in the small car class and the first production vehicle with a passenger module made from carbon fiber reinforced polymer (CFRP).
Volkswagen brought the ID.3, the first model in the ID family, onto the market. The modular electric drive kit (MEB) would also be used by Audi, Skoda and Seat.
