Processing aluminum and steel from solid blanks – reliable, autonomous, in-house
When you get into your car in the morning, you only notice the interior design subconsciously. The interior and displays are familiar, the coffee is in the center console as usual, and you're ready to go. If you're driving with someone else, you might take a closer look at the interior, perhaps you secretly compare. And yet don't waste a thought on what lies behind the visible forms and materials. Greidenweis GmbH is different. The company is one of the top addresses for anyone who has something that requires laminating and needs a suitable system. Greidenweis manufactures the complex laminating tools for these customer-specific systems on a turnkey solution from the CHIRON Group with two 5-axis machining centers from the 16 Series and a Variocell PALLET automation unit.
read time: 9 min Date of Article: 06/15/2024 read this article on one page
In February 2022, one of the first tasks for Fabio Neukirch, new Production Manager for Greidenweis in Spaichingen was to modernize manufacturing and the machine fleet. As a trained cutting machine operator and with eleven years of experience in sample and prototype construction, this was a welcome challenge for the industrial foreman. But what exactly was to be modernized and with what goals?
Background: Laminating systems, such as those Greidenweis has been manufacturing for Tier 1 suppliers to the automotive industry for over 25 years, are complex and always customized systems, 100 percent turnkey. A laminating tool that is commissioned in production can consist of a total of 300 individual parts in addition to the molded core component – molded part holder, numerous transfer slides, ribbed plates, pneumatic parts and many more. When it comes to large series production, there might be two, four or even eight of these laminating tools performing their task on a customized system and as part of a completely automated process: To professionally conceal everything that should not be visible in the vehicle.
 Fully satisfied with the solution (from left): Sales Manager Jens Rauser, Application Engineers Lars Flaig and Sascha Franke, Production Manager Fabio Neukirch.
Investment in doubled production volume
In order to get the »modernization of the machine fleet« project off to the right start, Fabio Neukirch first obtained an overview of the current orders in »his« production department: In his opinion, an in-house share of 30 percent to 70 percent external production was not an optimal ratio, neither economically nor in terms of production technology. He received planning support from Jens Rauser, Head of Sales since 2018 and very familiar with the challenges faced by customers in their market and the resulting requirements for Greidenweis. After various capacity and unit cost calculations, a work preparation analysis, the development of the production strategy and discussions with employees and supply partners, they knew which type of machine was the most suitable and how many of them would be needed to handle the projected production volume. »Using the solution developed together with the machine tool manufacturer, we wanted to more than double our in-house production and thus become more flexible, faster and more competitive,« says Jens Rauser, explaining the objective setting.
Fabio Neukirch summarizes the specifications as follows: »Batch sizes from one to ten, complex molded parts, our demand for high surface quality, production always from the solid material, mostly five-axis. The materials used still includes aluminum, but increasingly also high-strength steel, with processing times of two to six hours per component. And the whole thing is automated in three-shift operation.«
Powerful, dynamic machining, reliable automation
When Dirk Schmid received the inquiry, it was immediately clear that a classic tool and mold making solution was required. But which machining center from the CHIRON Group was the right one? And how do you safely automate the process to deliver the required high levels of autonomy? During an on-site visit, Dirk Schmid got to know the production facility in Spaichingen and spoke to Jens Rauser and Fabio Neukirch about the range of parts and the production strategy. With the requirement that the first molded part – whether made of aluminum or steel – had to meet the tight tolerance specifications in terms of surface quality and dimensional accuracy, it was clear to Dirk Schmid what qualities the production center had to have: Robustness, highly dynamic and stable conditions in the entire working area, especially with regard to dynamic compliance. This meant that two things were set in his concept: the 16 Series and two single-spindle machines for 5-axis machining.
»Whether at Greidenweis in tool and mold making, in medical technology, aerospace or automotive, whether aluminum or high-strength steels: The FZ 16 S five axis is made for precise machining of complex workpieces.»
Dirk Schmid
Head of Technical Sales D/A/CH CHIRON Group
The FZ 16 S five axis has successfully been equipped for other industries such as aerospace and specialized contract manufacturing for similar tasks by the application of the CHIRON Group. The machine dynamics enable very fast direction changes during 5-axis simultaneous multipass milling, which leads to a significantly shorter processing time for millions of program blocks. For roughing operations, whether high feed or heavy duty, the performance data and stability of the 16 Series allow the limits of the tool manufacturer's cutting data to be explored and the maximum metal removal rate Q to be milled.
At Greidenweis, a milling spindle with a high speed of 20,000 rpm should also contribute to greater productivity. With 57 kW of power and 140 Nm of torque, it would deliver optimum performance in daily machining practice for both aluminum and steel. As far as automation was concerned, there was only one solution for Dirk Schmid in view of annual production, shift operation, batch sizes, long machining times and machining volumes of up to 80 percent: a Variocell PALLET with gantry loader.
New capacities fully utilized, insourcing quota safely reached
The Variocell PALLET provides eight spaces for workpieces clamped in vices for the travel paths of the two FZ 16 S five axis of 660 x 660 x 500 mm (X – Y – Z). Machining on the production centers and loading the automation cell with workpiece blanks using the zero-point clamping system happens simultaneously. When one of the application technicians – Lars Flaig or Sascha Franke, for example – feeds in a workpiece, the cell is at its set-up position, where the other person loads or unloads it. The two have been working with the turnkey solution for around 15 months. Sascha Franke sums up what they value most: »The user-friendliness of the machine and automation, the impressive dynamics, i.e. speed, productivity. And, above all, the high quality that is delivered with the very first workpiece.«
Automation with further positive effects
The commissioning of the combination of FZ 16 S five axis and Variocell PALLET has set in motion a learning and development process at Greidenweis, from design to programming to production, which the company has been pursuing ever since and is increasingly exploiting the possibilities of automated production.
 Molded part foil carrier, running time 660 minutes – processed in batch size eight over three days and 16 hours unmanned, reliably and completely on the FZ 16 S five axis in OP10 and OP20.
One of these is preventive protection against collisions: All CAD/CAM programs now run through an NC simulation and are also backed up by ProtectLine. ProtectLine is one of the CHIRON Group's SmartLine digital systems and uses a digital twin to reliably protect the machining center against collisions caused by operating errors or incorrect programming. The digital machining process fully replicates the physical one, and the geometry of the virtual workpiece corresponds to that of the real one at all times thanks to automatic material removal simulation.
The turnkey solution with machines and automation also has an impact on work preparation. Production is now planned to be largely autonomous both in the third shift and from Friday evening to Monday morning.
»We have been impressed by the dynamics and stability of the production centers. The automation solution fits, all processes run reliably. And we no longer only manufacture 30 percent of our molded parts in-house, but a good 90 percent.«
Fabio Neukirch
Production Manager Greidenweis
Production Manager Fabio Neukirch is completely satisfied with the result of his modernization project: »Today, the throughput times of our molded parts are up to 25 percent shorter than before, and our in-house production is now 90 percent instead of 30 percent. Our strategy worked out perfectly, the decision to opt for a turnkey solution from the CHIRON Group was exactly the right one. We were able to increase our added value, the production centers are working at full capacity and are amortizing faster than planned.«
