Rotary tables for different machining strategies
The requirements for rotary tables vary significantly depending on the application. With the CRT200 and RTA220 rotary tables, the CHIRON Group therefore offers two proprietary solutions for different machining strategies on the 15, 18 and MILL Series. These are designed for either dynamic applications with short positioning times or high-performance machining with high process forces.
read time: 6 min Date of Article: 07/07/2026 read this article on one page
In addition to high-performance motor spindles, the CHIRON Group develops and manufactures other key mechatronic components, such as rotary tables, in-house. Development, manufacturing, assembly and service are closely interlinked. This ensures a high degree of transparency throughout the entire product life cycle, reduces interfaces and enables components to be precisely tailored to machining centers and machining processes.
The optimised CRT200 rotary table is designed for high rotational and holding torques during heavy-duty machining, whilst the new RTA220 is designed for maximum dynamics and short positioning times. These rotary tables are used worldwide in the 15, 18 and MILL Series, each offering clear advantages in terms of performance, productivity, availability and service.
»With its in-house developed rotary axes, the CHIRON Group offers two specifically designed variants that enable typical machining requirements to be met cost-effectively and in line with the process.«
Dipl.-Ing. Matthias Rudischhauser
Head of Rotation Systems
CRT200: High forces for demanding machining operations
The CRT200 rotary table is suitable for machining operations involving high process forces and workpieces with high mass. Typical areas of application include demanding aerospace applications, high-strength materials such as titanium or superalloys, and machining operations involving large and heavy clamping devices.
The rotary table is integrated into the 15, 18 and MILL Series as an A-axis or swivel axis and supports both 4-axis and 5-axis machining. It features a play-free, preloaded cycloidal precision gearbox. Thanks to tailored clamping of the gearbox components and optimised start-up behaviour using low-viscosity lubricants, the axis has been optimised for a wider range of applications.
»The CRT200 achieves high rotational and holding torques, thereby ensuring stable and reliable positioning even with high cutting forces and heavy workpieces. Machining operations from solid stock in particular benefit from the axis’s high overload capacity,« explains Dr Jens König, Head of Component Development.
RTA220: Performance for high-speed machining processes
The RTA220 rotary table is used as a highly dynamic A-axis in the 15 and 18 Series. It is designed for dynamic performance and speed, and is particularly suitable for the efficient machining of small and medium-sized workpieces made of aluminium or other easily machinable materials.
The Torque direct drive operates wear-free via electromagnetic power transmission and enables very high acceleration rates as well as rapid positioning movements in highly dynamic machining processes.
The very short positioning times reduce non-productive time and energy consumption per workpiece. This makes it possible to significantly increase the productivity of machining processes, particularly in applications involving frequent axis movements and short cycle times.
A comparison of the axes of rotation
Characteristics CRT200 RTA220
Typical Application Heavy-duty machining, high forces Dynamic 4-Axis Machining
Drive Cycloidal gear Direct Torque Drive
Focus High torque and overload capacity Very high dynamic performance and acceleration
Rated torque 1,200 Nm 211 Nm
Acceleration approx. 2.2 rad/s² approx. 20 rad/s²
Positioning time 0°/180° 0.9 s 0.4 s
Maintenance costs low virtually wear-free
Particularly suitable for Large workpieces, titanium, aerospace Aluminum, small components, high speed
Two machining strategies – illustrated using the DZ 15 W as an example
At EMO 2025, the CHIRON Group demonstrated the different strengths of the two rotary axes in live operation on a DZ 15 W with integrated automation. On one side of the table, the highly dynamic RTA220 was used to machine an aluminium pump housing with short cutting times, high feed rates and rapid positioning movements. On the other side, the CRT200 was used to machine a grey cast iron fan cover, utilising long engagement times, high feed forces and high holding torque.
The rotary tables are manufactured at the CHIRON Group Precision Factory in Neuhausen ob Eck. At the sites of the CHIRON Group in Germany, Poland and China, the rotary tables are fitted into the machines produced there. The close integration of development, manufacturing and assembly enables rapid coordination. At the same time, customers benefit from rapid response times for support and service calls. Technical queries can be resolved directly, and the teams possess in-depth expertise regarding their own mechatronic components.
Demonstration at EMO 2025 using a DZ 15 W with Variocell UNO: autonomous production of pump casings using the RTA220 on one side of the table, and machining of fan covers using the CRT200 for the mechanical engineering sector on the other.
